Aliexpress : codes promo valables sur tout le site
 some measurements
2 participants
Orangebullit
Orangebullit
some measurements Empty
MessageSujet: some measurements   some measurements Icon_minitimeDim 2 Oct - 1:50
Hello. Can someone help me with two measurements on the Maxi? I need the exact distance on this two marked lines.
Thank you for your help top some measurements Namnlszg
Orangebullit
Orangebullit
MessageSujet: Re: some measurements   some measurements Icon_minitimeMer 5 Oct - 7:13
nobody?
Lance
Lance
MessageSujet: Re: some measurements   some measurements Icon_minitimeMer 5 Oct - 15:58
Hi Orange built,
why would the dimensions be any different from a regular T1 or T2. The center line of the rear axle should be the same....the position of the motor, transmission and CV joints are no different from the Maxi to the T1 or T2. The only difference I am aware of is the Maxi runs a larger rear tire.
Orangebullit
Orangebullit
MessageSujet: Re: some measurements   some measurements Icon_minitimeMer 5 Oct - 16:08
Yes I did see that. But what is the distance on the T1/T2?
Orangebullit
Orangebullit
MessageSujet: Re: some measurements   some measurements Icon_minitimeVen 7 Oct - 16:01
Please, anyone? I would like to continue with my Renault this weekend but I need this measurements to do that. What is the exact distance from the lowest back corner of the door to the wheel centre?
Kind Regards
Rikard
Lance
Lance
MessageSujet: Re: some measurements   some measurements Icon_minitimeSam 8 Oct - 21:07
Hey Orangebullit,
I don't know how accurate of a measurement you are looking for, but I measured from the back of the door to certain of axle and came up with 29" (inches) it is not an easy measurement because the rear wheel well sticks out so far. The other measurement from bottom of window to center axle is 22 1/2" inches....take note, that this measurement will very drastically from car to car depending on how the car is set up for ride height. Again, this measurement was not easy to take either, so both measurements are not exact.
I hope this helps
Orangebullit
Orangebullit
MessageSujet: Re: some measurements   some measurements Icon_minitimeSam 8 Oct - 21:56
Thank you! It will give me an idea of how I will mount my wheel hub:)
Lance
Lance
MessageSujet: Re: some measurements   some measurements Icon_minitimeDim 9 Oct - 2:12
What are you building?
some measurements
